Is relating tables the right solution?
375
10-16-2019 07:24 AM
Miguel-Fernandez
I am trying to analyze commute patterns using LODES data from the US Census. I downloaded a table that contained fields for home_census_block, work_census_block, and num_of_jobs. I joined that table to the census block geography using home_census_block as my join field. I then made a selection of census blocks that I wanted to analyze as the starting location for the commutes and made a new layer from that selection. I then created a relationship between the census block geography layer and the census block selection. The parameters for the Add Relate tool are:
Layer Name: census_block_geography
Input Relate Field: census_block_geography.GEOID10
Relate Table: census_block_selection
Output Relate Field: work_censusblockID
Cardinality: One to many
The Add Relate tool runs fine with no errors but I can't seem to get what I want. What I'm trying to see is what census blocks people are working in that live in the selected area. I have tried using the 'select related records' from the attribute table menu but nothing happens. I'm wondering if this is the right approach or is there something different I should be doing to get the desired results. Any guidance would be much appreciated.
Miguel
Miguel Fernandez
RobertBorchert
Frequent Contributor III
Unfortunately you cannot make symbols, definition queries, or queries based on a relate.
I think you can do it with some sort of relate table but I have worked on that yet.
Try a JOIN instead
