AnsweredAssumed Answered
Failed to execute (TableToExcel) - ArcGIS Pro 2.3.3
Question asked by 916529658@sfsu.edu_SFSU on Oct 15, 2019
Latest reply on Oct 17, 2019 by 916529658@sfsu.edu_SFSU
I created a small table (less than 200 rows) then attempted to export to Excel. Table to Excel tool consistently fails.
If send the tool script with my parameters to the Python window and run the tool, the following error results - it is the same and repeatable:
import arcpy
arcpy.conversion.TableToExcel("thesisHistAnalysis", r"C:\Users\PCD\Documents\ArcGIS\Projects\Thesis\thesisHistAnalysis.xlsx", "ALIAS", "DESCRIPTION")
  File "<string>", line 1, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\conversion.py", line 99, in TableToExcel
    raise e
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\conversion.py", line 96, in TableToExcel
    retval = convertArcObjectToPythonObject(gp.TableToExcel_conversion(*gp_fixargs((Input_Table, Output_Excel_File, Use_field_alias_as_column_header, Use_domain_and_subtype_description), True)))
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Traceback (most recent call last):
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\TableToExcel.py", line 306, in <module>
    arcpy.GetParameter(3))
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\TableToExcel.py", line 171, in table_to_excel
    fields = get_field_defs(in_table, use_domain_desc)
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\TableToExcel.py", line 123, in get_field_defs
    subtypes = arcpy.da.ListSubtypes(in_table)
OSError: thesisHistAnalysis
Failed to execute (TableToExcel).
Is there another approach - maybe a pandas or similar solution if the ESRI script does not work? Is ther a way to troubleshoot ESRI Python that previously operated as anticipated? Are there requirements wrt the table itself that could be related to the error?
Outcomes
