Digital Maps
431
10-10-2019 12:40 PM
JenniferSniffen
Is anyone out there accepting subdivision or condo maps digitally and then dropping them into ArcMap?  We are interested in learning from you if you are.  Ideally, we would like to accept maps in a digital format and then instead of re-tracing and re-creating all the line work we would like to be able to import the map into our Tax Map.
Tags (1)
AdrianWelsh
MVP Honored Contributor
Jennifer Sniffen, when you say accepting subdivision maps digitally, what format are you referring to? CAD files (dwg, dgn)? PDFs?
If they are CAD, it really helps if they have a spatial reference (it might be a good idea to require that in submissions). That way you can place them into ArcMap (or Pro) in the right place). Otherwise, you might have to georeference it in.
Here are some resources on how to do that in ArcMap:
About georeferencing CAD data—ArcGIS Pro | ArcGIS Desktop
Georeferencing CAD datasets—Help | ArcGIS for Desktop
JenniferSniffen
Thank you so much for replying, Adrian.  Do you happen to know any organizations or municipalities that are currently doing this?  I would ideally like to learn from someone else's experience.
AdrianWelsh
Jennifer,
I would suggest reaching out to your local governments and seeing what process they take to do this sort of thing. That might be a good start.
