AnsweredAssumed Answered
Divide shp in about 20-50 adjacent polygons?
Question asked by JB1234510 on Oct 9, 2019
Latest reply on Oct 10, 2019 by JB1234510
I would like to divide a shp in about 20-50 adjacent polygons. I have the following script but the while loop (line 54) becomes endless if there are less than 10 adjacent polygons to select. Any ideas for a better solution?
# -*- coding: cp1252 -*-
import arcpy
arcpy.env.workspace = "in_memory"
Alk_Sel = r"R:\Daten\sgb_Planungen\2013\Saalbachniederung\Eigentuemer\ALK_merge_E.shp"
alk_sel_Layer = "alk_sel_Layer"
InFile = r"C:\temp2\InFile.shp"
def SicFeature():
    arcpy.CopyFeatures_management(Alk_Sel, InFile)
    arcpy.MakeFeatureLayer_management(InFile, alk_sel_Layer)
def AddField():
    arcpy.AddField_management(alk_sel_Layer, "Round", "LONG")
def selectMin():
    sum = arcpy.GetCount_management(alk_sel_Layer)
    print sum
    i = 0
    for i in range(1, int(sum.getOutput(0)), 10):
        i += 1
        Expression = """ "Round" = {} """.format(0)
        arcpy.MakeFeatureLayer_management(InFile, alk_sel_Layer, Expression )
        sum1 = arcpy.GetCount_management(alk_sel_Layer)
        print('{} has a sum of {} records'.format(alk_sel_Layer, sum1[0]))
        MyList = list()
        cursor = arcpy.da.SearchCursor(alk_sel_Layer, "FID")
        for row in cursor:
            MyList.append(int(row[0]))
        print 'Minimum: {0}'.format(min(MyList))
        expression1 = min(MyList)
        arcpy.SelectLayerByAttribute_management(alk_sel_Layer, "NEW_SELECTION", """ "FID" = {} """.format(expression1))
        result1 = arcpy.GetCount_management(alk_sel_Layer)
        while (int(result1.getOutput(0)) < 10):
            arcpy.SelectLayerByLocation_management (alk_sel_Layer, "INTERSECT", alk_sel_Layer)
            print(result1)
        arcpy.CalculateField_management(alk_sel_Layer, "Round", i)
        OutFile = r"C:\temp2\OutFile_{}.shp".format(i)
        arcpy.CopyFeatures_management(alk_sel_Layer, OutFile)
SicFeature()
AddField()
selectMin()
Outcomes
