update attribute value and refresh tablecontrol
1179
10-06-2019 07:38 PM
VictorTey
ProGuide TableControl · Esri/arcgis-pro-sdk Wiki · GitHub
I am following this guide. On click of a button, I am attempting to change a attribute value and then save that value in the featureClass and update the tableControl. However, the save seem to be locking the UI thread and the table doesn't updated, the refresh icon just keeps spinning. If I close the pane and open it again, the table is updated.
I have to use featureclass not not featurelayer as the layer I am updating most likely will not be added to the active map. Would anyone be able to advise?
public ICommand AddToMapCommand
            get
                if (_addToMapCommand == null)
                    _addToMapCommand = new RelayCommand(() =>
                        //var oid = _tableControl.GetObjectIdAsync(_tableControl.ActiveRowIndex).Result;
                        QueuedTask.Run(() =>
                            IReadOnlyList<long> oids = _tableControl.GetSeletedObjectIds();
                            using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"D:\SDE connection\LEA-304867.sde"))))
                                using (FeatureClass featClass = geodatabase.OpenDataset<FeatureClass>("arcgis.DBO.polygonfeaturelayer"))
                                    EditOperation editOperation = new EditOperation();
                                    editOperation.Callback(context => {
                                        QueryFilter queryFilter = new QueryFilter
                                            ObjectIDs = oids
                                        using (RowCursor cursor = featClass.Search(queryFilter, false))
                                            while (cursor.MoveNext())
                                                using (Feature f = (Feature)cursor.Current)
                                                    f["NAME"] = "Y";
                                                    f.Store();
                                    }, featClass);
                                    bool success = editOperation.Execute();
                                    if (success)
                                        Project.Current.SaveEditsAsync();
                                        this._tableControl.Refresh();
                                    if (!success) throw new Exception(editOperation.ErrorMessage);
                return _addToMapCommand;
by Anonymous User
Not applicable
Victor,
One thing you'll need to do when updating via a callback is to invalidate the row before and after a store.
Take a look at the Modifying a Row snippet.
VictorTey
Sean Jones‌ thanks for that. However that did not work and the UI thread is still hanging.
by Anonymous User
Not applicable
Hi Victor,
Just use wpf DataGrid and extend it to allow multiselection and then bind with datasource.
That should be easier if you don't have specific purpose to use that TableControl
