AnsweredAssumed Answered
Calculate field string into int and float => error
Question asked by pan_gis on Oct 6, 2019
Latest reply on Oct 20, 2019 by curtvprice
I am running a model.
1. for field 1(string)  I have "integer numbers" and a value "nan"
      I use field calc with the expression: !ACmodeString!.replace("nan","<Null>")
2. Once I have the null records I run  again Filed Calc to copy these values from the string field into a integer field with a expression like Field1(string) = Field2(integer)   [ I have tried both VB and Python]
a. with python I get this error:
ERROR 999999: Error executing function.
The value type is incompatible with the field type.
b. with python again
int(!acmodestring!)
erro:
ERROR 000539: Error running expression: int(u"<Null>")
  File "<expression>", line 1, in <module>
ValueError: invalid literal for int() with base 10: '<Null>'
c. with VB I get an alert:
If I click yes it finishes.
the same happens for a filed that needs to be converted in float.
I need to get rid of this alert.
The issue seems to be the null value.
Thanks!
Outcomes
