I am getting an error when trying to create a sample template.
Hi Rickey,
Are you using ArcGIS Online or ArcGIS Enterprise?
I guess that would be helpful information.
I am using ArcGIS enterprise. I am also created the survey in survey123 Connect
And to check, the ArcGIS Enterprise implementation is reachable via the internet, which is required for the feature service functionality? See Use Survey123 with ArcGIS Enterprise—Survey123 for ArcGIS | Documentation for more information.
Yes it is able to reach the internet. I started one before on a similar survey but for some reason I am getting an error this time.
It might be best to open an Esri Support ticket to further diagnose what the issue might be.
This might be a "public facing" issue with your portal. I would recommend reading the documentation and having a word with your IT.
https://doc.arcgis.com/en/survey123/reference/survey123withenterprise.htm
I can create a report using a different survey. I am not sure "public Facing" is the issue.
