AnsweredAssumed Answered
Customized Popup not supporting style?
Question asked by n.ueberschaeresri-rw-esridist Employee on Oct 3, 2019
Latest reply on Oct 10, 2019 by n.ueberschaeresri-rw-esridist
I customized the popup for one of my layers to show only three attributes of which two display arcade expressions. Because I also want to hide the label if the result is empty I designed the popup with a table to reproduce the same design as the "normal" popups. I added a style so the attribute names are equally grey-ish as regularly. This works great in my web map until I close it -  when I open the map again or use the map in an web application the popup seems to remove the "style" element and puts my customized style as part of the popup text.
Is that an expected behaviour?
It seems to keep the styling when using css inline though...
Outcomes
