i am trying to add a URL to specific properties on my map
608
10-03-2019 08:29 AM
eliottrutzky
I want to add a url to my map points so when i create a webapp i am able to redirect the viewer to a more specific map of the individual properties.
is this possible?
David
by Esri Contributor
You could get the URL for the map and put it into a new attribute field on your points. In the web map, configure the pop-up to display the field or use the field to configure a custom pop-up.
There is a discussion about a few techniques on this GeoNet post:
Enable Pop-ups in ArcGIS Online with Hyperlinks
eliottrutzky
thank you! i tried messing around with the attributes before and couldnt seem to get it to work.
maybe i was going about it the wrong way.
David
by Esri Contributor
I think there is going to be better support for this in our new Map Viewer. It is getting a major over haul and the beta will be released any day now. You'll be able to try out the beta without having to sign up or anything. You can read about it here.
I read this at the bottom of the post: Show attachments in pop-ups to streamline the viewing experience and eliminate the need to use Arcade or click a link to view the attachment.
