Survey123 Feature Report: Failed to parse..
1167
10-01-2019 12:25 PM
JordanMiller4
Occasional Contributor III
Any ideas why adding fields from a related table to a word doc template would generate the error from the image? You would think this function would work with the point fc and it's related tables that were published to AGOL.
LynetteDooley
I also am having this parsing issue. I cannot save or publish my existing survey.
JamesTedrick
Esri Esteemed Contributor
Hi Jordan,
Without seeing the full schema and template, this is a bit difficult too debug.  Note that if the F8OWNER field is in the parent layer of a repeat, you should use the format <TABLENAME>.<FIELDNAME> to access the value - refer to the note at Feature report templates—Survey123 for ArcGIS | Documentation
ReubenWilliams
Same again with parsing a field inside a repeat.
ReubenWilliams
I've worked it out. In my case I had a nested table in my docx document, and this prevented the parsing of repeats. Running the repeat in a new, separate table, got it running.
