Calculating fields using Python
478
09-26-2019 02:50 PM
JeanetteChamorro
I'm having the hardest time coming up with a Python expression to calculate fields based on multiple conditions. I need to be able to associate a material code to a feature that meets two specific conditions. For example:
The logic I'm trying to use is:
if CATEGORY_NAME == TAIL AND Calculated_length < 500 equals MATERIAL_CD =  "10835549"
elseif CATEGORY_NAME == TAIL AND Calculated_length > 500 equals MATERIAL_CD =  "10796850"
My python code looks like this
I'm sure there is something wrong with it but I cannot figure out what it is. Any insight would be greatly appreciated! Thank you.
DanPatterson_Retired
The logic is as follows
def Reclass(a, b):
    """just make it generic"""
    if a == "TAIL" and b < 500:
        return 10835549
    elif a == "TAIL" and b >= 500:
        return 10796850
    else:
        return -1
Reclass("TAIL", 100)
10835549
Reclass("TAIL", 600)
10796850
# ---- in the field calculator, you replace the actual numbers with
Reclass(!CATEGORY_NAME!, !CALCULATEDLENGTH!)
See line 19 for field calculator syntax... you pass the field names containing the values to the function
