I am looking for a Print Widget that can be customized to print results data as well as highlighted parcel map and (from search widget). Shall I start with the original print widget that comes with the WAB, or some enhanced version that I can build upon? Thank you!
Print Plus Widget Version 1.1.6 July 12, 2015 (LIVE Preview does not work)
Hi Bing Jing,
Are you going to print your highlighted parcels in a single map, or one map per parcel (feature map)?
If you only need single map, I would suggest to use Report class:
Report class—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Otherwise you probably need GP service + Data Driven Pages/Map Series to print feature maps in a report.
Leo.
I will try the Report class. Thank you Leo.
