So I'm following Iterating insert geometry statements via T-SQL which I have used many many many many mnay many many times in the past to do bulk inserts from non-SDE sources into a SDE feature class. Now I'm on SDE 10.7.x and using the following:
DECLARE @RowCount INT
SET @RowCount = (SELECT COUNT(*) FROM [db1].[dbo].source_table WHERE FCSUBTYPE = 22 OR FCSUBTYPE = 23 OR FCSUBTYPE = 24 )
DECLARE @iterator INT
SELECT @iterator = MIN(OBJECTID) FROM [db1].[dbo].source_table WHERE FCSUBTYPE = 22 OR FCSUBTYPE = 23 OR FCSUBTYPE = 24
WHILE @iterator is NOT NULL
BEGIN
DECLARE @id as integer
EXEC dbo.next_rowid 'dbo', 'dest_table', @id OUTPUT;
INSERT INTO [db2].[dbo].[dest_table]([OBJECTID],[CREATEDATE],[EDITDATE],[MAPMETHOD],[MAPSOURCE],[SOURCEDATE],[XYACCURACY],[NOTES],[GlobalID],[COUNTY],[MANAGEMENTZONE],[QUADNAME],
[ROAD],[PARKDISTRICT],[STATE],[WATERSHED],[TRAIL],[X_COORD],[Y_COORD],[LAT],[LON],[ELEVATION],[LOC_NAME],[FC_SUBTYPE],[LOCATION_DESCRIPTION],[Shape],[STREAMNAME],[YEAR],[VALID_RESULT],
[PUBLICDISPLAY],[DATAACCESS],[UNITCODE],[UNITNAME],[REGIONCODE],[CREATEUSER],[EDITUSER])
SELECT @id, [CREATE_DATE],[EDITDATE],CASE WHEN [MAPMETHOD] ='HDIG' THEN 'Digitized' WHEN [MAPMETHOD] ='UNKN' THEN 'Unknown' WHEN [MAPMETHOD] ='AGPS' THEN 'Autonomous GPS' WHEN [MAPMETHOD] ='DERV' THEN 'Feature Extraction' WHEN [MAPMETHOD] ='' THEN 'Unknown' WHEN [MAPMETHOD] IS NULL THEN 'Unknown' END AS [MAPMETHOD],
[MAPSOURCE], [SOURCEDATE],CASE WHEN [HERROR] = '>10m <=100m' THEN '>=14m' WHEN [HERROR] = '>1m <=5m' THEN '>=1m and <5m' WHEN [HERROR] = '>5000m' THEN 'Scaled' WHEN [HERROR] = '>5m <=10m' THEN '>=5m and <14m' WHEN [HERROR] = 'Unknown' THEN 'Unknown' WHEN [HERROR] = '' THEN 'Unknown' WHEN [HERROR] IS NULL THEN 'Unknown'END AS [XYACCURACY],
[NOTES],[GIS_LOCATION_ID],[COUNTY],[MANAGEMENTZONE],[QUADNAME],[ROAD],[PARKDISTRICT],[STATE],[WATERSHED],[TRAIL],[X_COORD],[Y_COORD],[LAT],[LON],[ELEVATION],[LOC_NAME],[FCSUBTYPE],[LOCATIONDESCRIPTION],
[SHAPE],[STREAMNAME],[YEAR], CASE WHEN [VALID] = 'Certified' THEN 'Certified' WHEN [VALID] = '' THEN 'Raw' WHEN [VALID] IS NULL THEN 'Raw' END AS [VALID_RESULT],'No Public Map Display' AS [PUBLICDISPLAY],
'Secure Access Only' AS [DATAACCESS], 'GRSM' AS [UNITCODE], 'Great Smoky Mountains National Park' AS [UNITNAME], 'SER' AS [REGIONCODE], 'GRSM User' AS [CREATEUSER], 'GRSM User' AS [EDITUSER]
FROM [db1].[dbo].source_table WHERE FCSUBTYPE = 22 OR FCSUBTYPE = 23 OR FCSUBTYPE = 24 AND objectid = @iterator;
SELECT @iterator= MIN(OBJECTID) FROM [db1].[dbo].source_table WHERE @iterator < OBJECTID AND FCSUBTYPE = 22 OR FCSUBTYPE = 23 OR FCSUBTYPE = 24
END
Which results in the whole thing looping as many times as there are objects meeting the where clause. E.g it's selecting all 566 rows, 566 times.
Christian Wells This leads me to believe that how a new OID is generated has changed since that 2014 blog post?
I save all my SQL code, so I opened up the last one I ran successfully on a 10.5.x SDE, and yup, no change other than the where clauses (which I removed to see if that was the cause, which they are not).
Thanks for sharing your findings. Let me take a look at 10.7 and get back to you. What version of SQL Server are you using?
