AnsweredAssumed Answered
Server 10.7.1 says layer not configured for sync
Question asked by lcecil5 on Sep 26, 2019
Latest reply on Jan 6, 2020 by lcecil5
I'm trying to publish a dataset from ArcGIS Pro 2.4.1 to Server 10.7 for use in a Collector app. I've gone through all the steps to turn this into an editable, sync-enabled dataset. The SDE source for the data is registered with the server, I've added global IDs, enabled archiving (data is non-versioned), and enabled editor tracking. I've enabled editing and sync under the configuration pane of Publish Map Service in Pro. The service publishes successfully, but won't start. I see this error in the logs: Failed to construct instance of service 'BESC_Parkin_Main_Level.MapServer'. Layer(s) or table(s) are not configured for Sync. I'm not sure what I'm missing here.
Outcomes
