can viewshed analysis is able to perform offline
607
09-25-2019 11:28 PM
Sharan_saiGudibanda_Nagesh
I would like to get the viewshed analysis from a point on the map
  • This process should happen completely offline.
  • I can able to load the arcgis Maps from offline
  • But i want to get the geoprocessing things to be done offline
Please do reply as soon as possible, If a sample code is present do attach the file it will be a great help
MichaelBranscomb
Esri Frequent Contributor
Yes, maps and analysis can both be achieved offline with ArcGIS Runtime.
For more information see:
Work offline—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Manage analyses with analysis overlays—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Geoprocessing—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Local Server—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Note the Local Server component is required for full offline geoprocessing (beyond the visual analysis provided by the analysis overlays). Local Server is only supported by the WPF API within ArcGIS Runtime SDK for .NET.
Cheers
Mike
Thanks for the reply.
My Local server shows the error "Geoprocessing service failed to start"
I was using ArcGIS runtime 100.5 and local server 100.5, I have also set the deployment XML file unwanted things to false
Regards
G.N.SharanSai
