I'm trying to use my portal for ArcGIS QuickCapture but I keep getting an invalid Client ID error 400. Any ideas?
Solved! Go to Solution.
You will get a client-id error when using versions of Enterprise prior to 10.7.1. We do not officially support QuickCapture in anything older than 10.7.1 but this document, which you can use at your own risk, describes how to make things work if you happen to be using ArcGIS Enterprise 10.7.
