I am using WAB 2.13. When I add the eSearch widget (2.12) and Query widget in the same app, the presence of the the eSearch widget causes the '.query-result-action-button' under the results tab of the Query widget to not open.
Any ideas on what might be causing this?
Any help would be greatly appreciated!
Jason
Solved! Go to Solution.
Jason,
OK I see you got a bad download of the 2.12 eSearch widget. re-download and you should be good to go.
Jason,
I just tested eSearch 2.12 and the query widget in WAB Dev 2.13 and there is no conflict...
I thought it was odd, so I started with a fresh copy of 2.13. only added those two widgets. did not configure the eSearch widget. configured the Query query widget using different layers (as well as WebMaps) and when i select the parcel, apply the search and try to click the 'more options' button nothing happens. If I remove the eSearch widget it works fine.
Test app is here - ArcGIS Web Application
Jason,
That was it! Thanks!!
