mid
828
09-18-2019 04:51 PM
kenWILKINS
I'm doing a calculated field in Arcgis 10x desktop.
ROOTID field is a parcel ID (from another organization).   example:  06-07- 43-0462-0000-0000
I'm changing the number in the field ASI_PID to be calculated to be:    07  43046200000000
ASI_PID is type: String and length=50
My calc is:    Mid([ROOTID],4,2)+" "+Mid([ROOTID],8,2)+Mid([ROOTID],11,4)+Mid([ROOTID],16,4)+Mid([ROOTID],21,4)
But I get:   07  4-048-000-000     I don't want the dashes, and as you can see, I'm not adding any.  I'd like a space after the first two numbers.   I tried changing how many numbers at the position (like 4,5) but it still puts in the dash and leaves out a number.
What am I doing wrong?
Thank you!
DanPatterson_Retired
Ken
tick python on
dump your expression from the last line and replace with mine
there is no prelogic code block
"".join([str(i) for i in !ROOTID!.split("-")[1:]])
python parser
rootid = '06-07- 43-0462-0000-0000'  # which would be !rootid! in the expression
"".join([str(i) for i in rootid.split("-")[1:]])
'07 43046200000000'
kenWILKINS
Dan,
Thanks for the reply. I don’t speak Python. Do I add this in the codeblock with my expression in the calc field ? See pic
Thank you
Ken Wilkins
Hurricane, WV
Ken
tick python on
kenWILKINS
Thank you!    I ran mine first to get the numbers, then ran yours to eliminate the dashes.
Thanks!
