AnsweredAssumed Answered
Can you set min/centered/max value for above and below or centered on?
Question asked by PhilipDub on Sep 18, 2019
I am trying color fill US counties by volume balance (where we have positive and negative numbers).  Is there a way to fix the max/centered/min values to be used by the color ramp scale in an above and below color theme?  I want the fill to remain the same no matter how the data is filtered, as I want negative to always be on the blue spectrum and positive values to be on the red spectrum.
If you manually change the max/centered/min values, the change won't be saved when the filtered data changes.
Any ideas?
Outcomes
