Problem with ArcGIS Portal Installation
2360
09-18-2019 01:38 AM
DambéSANWOGOU
Hello, I have a problem installing my portal
There was an error creating your initial administrator account.
Migration failed. Upgrade failed. No license file specified.
For more information, please view the log messages located in the content directory specified during setup (C:\arcgisportal\logs\).
Best regards,
Anselme
GIS Developer
JonathanQuinn
Esri Notable Contributor
What version are you using? I'm assuming you installed, tried to create site, and it failed a first time. Was the error something about the index configuration failed? A db folder is created during createSite and if the process fails because of an index problem, we don't delete the folder. We're looking to fix this. What happens next is that the portal thinks it's in "upgrade mode" rather than creating a new site. If this is a new install, make sure the db folder doesn't exist under C:\arcgisportal\ and try again.
DambéSANWOGOU
Ok thanks Jonathan Quinn
I delete the db folder.
I have this error
java.lang.Exception: Failed to start the database server. The startup timed out. Please check the log file at C:\arcgisportal\logs\\database\pgsql.log.
Best regards,
Anselme
GIS Developer
JonathanQuinn
Take a look at my comment here for what to do next:
Take a look at the Event Viewer for why the database won't start. You can start by tracing back 5 minutes from when this error is written to the logs:
Failed to start the database server. The startup timed out. Please check the log file at C:\arcgisportal\logs\database\pgsql.log
For example look at what's happening around 11:43:23 in the Event Viewer for PG errors based on this message:
<Msg time="2019-09-12T11:48:23,756" type="WARNING" code="217062" source="Portal" process="1544" thread="1" methodName="" machine="machine" user="" elapsed="">Error checking status of database. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgisportal\logs\database\pgsql.log.</Msg>
You may want to reach out to Support as well to have a look.
AlexBurnett
Hello, sorry to resurrect an old support thread. Were you able to resolve this issue, and if so what was the fix?
I have encountered the same issue and am working with Esri Tech Support towards a resolution but am interested to know your findings.
