Export a Map in PNG Format
887
09-17-2019 08:59 AM
NadirHussain
Occasional Contributor II
Dear All,
My Project manager want a custom report like the image given below.how can i achieve this task using arcgis java script api.please help.Thanks in advance
AndrewKniowski1
Hi, we most often see customers approaching functionality such as this through a print service.  We have a print widget that makes it simple to implement in the JavaScript API.  It is possible to create custom print templates with your own print service if desired.
NadirHussain
Dear Andrew ,
I am using arcgis java script 3.29.how to achieve this task in that api.
Thanks in advance.
by Anonymous User
Not applicable
Hi Nadir,
For javascript side you can refer to that : Print | ArcGIS API for JavaScript 3.29
In order to use your desire print layout like what you described, it is better to publish print gp task with custom layout.
And then use that gp task by above js reference link I mentioned.
Below is how to publish
Publish an additional print service with custom layouts from ArcMap—Documentation (10.7) | ArcGIS En...
Share a print service web tool with custom layouts from ArcGIS Pro—Documentation (10.7) | ArcGIS Ent...
