Is there any way to export the selected records from a table or any type of card to a csv or text file when the records are filtered?
Solved! Go to Solution.
Hello Alex,
As an analyst, you can export data using this option: Export data—Insights Get Started | Documentation
Or, are you asking about the ability to export as a viewer of the shared Insights workbooks/pages?
Hello Alex,
I won't speak for OP, but trying to figure out how to export, for example, a summary table card in a shared page to a CSV is how I found this thread. In other words, it'd be great if the end user could toggle some filters or select some features and then be able to export a summary table of their filtered/selected data for use in software they are already comfortable using and have access to.
I have the same question. I know how to export from my workbook, but I need to be able to export filtered summary tables from a shared page. I don't want the user to potentially be able to change any of the data they are filtering, just export the results. Maybe even be able to export the map card or chart as a pdf or image might be nice as well. But really need the table export.
