Dear All,
I'm beginner to GeoEvent , I need your help please , I was trying to consume a REST API URL "MiX Integrate " to GeoEvent if possible ?? if so how to configure input which Rest API URL ,Do I need to develop a specific input to read my Api URL? would you please guide me How to start ?
I hope to hear from you
I really need your guidance on this
Thanks and Regards,
Khadija
Hi Khadija,
To get familiar with GeoEvent, I would recommend go through the Introduction Tutorials: https://www.arcgis.com/home/item.html?id=b6a35042effd44ceab3976941d36efcf
For your use case you may find this tutorial on how to create/configure a Poll an External Website for JSON helpful as well: https://www.arcgis.com/home/item.html?id=b6a35042effd44ceab3976941d36efcfhttps://www.arcgis.com/home/item.html?id=b087b8193b55465cb94d4c451dd541ac
As for working with MiX Integrate, it looks like to get started you'll need a client id, client secret, base url, and the endpoint for the operation you want to use (e.g. /api/events/assets/latest/{quantity}).
Hope this helps,
Earl
Hi Medina,
thanks for your email.
I have quite good introduction , but I need your help with configuration .
I do have them ( a client id, client secret, base url, and the endpoint for the operation you want to use ) . but its seems its difficult cuz its need access and token .
however I configure it as showing below , would you please advise if its correct ?
the ERROR says : Second attempt failed. Giving up. (https://integrate.om.mixtelematics.com/api/assets/1 --- Connect to integrate.om.mixtelematics.com:443 [integrate.om.mixtelematics.com/185.64.24.232] failed: Connection timed out: connect)
thanks,
KHADIJA
