astratton@fs.fed.us
Generating list of datasets for Analyze Datasets Tool
Discussion created by astratton@fs.fed.us on Sep 13, 2019
I have a few questions about the suggested Python scripting for the Analyze Datasets tool. The suggested Python (from  Analyze Datasets—Help | ArcGIS Desktop is:
# Import system modules
import arcpy
import os
# set workspace
# the user in this workspace must be the owner of the data to analyze.
workspace = arcpy.GetParameterAsText(0)
# set the workspace environment
arcpy.env.workspace = workspace
# NOTE: Analyze Datasets can accept a Python list of datasets.
# Get a list of all the datasets the user has access to.
# First, get all the stand alone tables, feature classes and rasters.
dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters()
# Next, for feature datasets get all of the datasets and featureclasses
# from the list and add them to the master list.
for dataset in arcpy.ListDatasets("", "Feature"):
    arcpy.env.workspace = os.path.join(workspace,dataset)
    dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets()
# reset the workspace
# Get the user name for the workspace
userName = arcpy.Describe(workspace).connectionProperties.user.lower()
# remove any datasets that are not owned by the connected user.
userDataList = [ds for ds in dataList if ds.lower().find(".%s." % userName) > -1]
# Execute analyze datasets
# Note: to use the "SYSTEM" option the workspace user must be an administrator.
arcpy.AnalyzeDatasets_management(workspace, "NO_SYSTEM", dataList, "ANALYZE_BASE","ANALYZE_DELTA","ANALYZE_ARCHIVE")
print("Analyze Complete")
Questions:
  1. Something I am unclear on and doesn't seem to be addressed in the documentation, should the Analyze Datasets tool should be run for BOTH the feature dataset AND feature classes and other datasets contained within a feature dataset, i.e. should line 16 in the script above be edited to include a list of feature datasets, such as in line 8 in the script below?
  2. On line 20 above an iteration through all the feature datasets begins. The workspace is set to the current feature dataset. A list of feature classes and datasets is then generated and added to the list. When the Analyze Datasets tool is run, my understanding is that 'Dataset names use paths relative to the input workspace; full paths are not accepted as input.' If that is the case, shouldn't the feature classes and datasets that reside within a feature dataset added have a relative path that includes the name of the feature dataset when added to the data list? If so, would the code need to be altered as below on lines 14-21?
arcpy.env.workspace=workspace
dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters()  + arcpy.ListDatasets('', 'Feature')
# from the list and add them as a relative path to the master list
for dataset in arcpy.ListDatasets('','Feature'):
    fc_list = arcpy.ListFeatureClasses()
    for fc in fc_list:
        fc_add = os.path.join(dataset, fc)
        dataList.append(fc_add)
    ds_list = arcpy.ListDatasets()
    for ds in ds_list:
        ds_add = os.path.join(dataset, ds)
        dataList.append(ds_add)
# reset workspace...
 Thank you in advance for any clarification or suggestions!
Outcomes
