Using Dagbanli language in Survey123
293
09-13-2019 05:02 AM
KevinLambeth1
New Contributor III
One of our partners is doing work in Ghana and would like to use the Dagbanli translation in the form, but it isn't on the ISO 639 list of languages.  Is there a workaround or option to add a Dagbanli translation into our survey without causing other issues?
JamesTedrick
Esri Esteemed Contributor
Hi Kevin,
While the examples in our documentation use ISO-639 2 character codes, you can also provide the ISO-639 3 character code (in this case, Dagbani (dag) ).
KevinLambeth1
New Contributor III
Thanks James!  This worked perfectly
