artifact
PopupExpression and PopupManager relationship?
Discussion created by artifact on Sep 11, 2019
Latest reply on Mar 23, 2020 by artifact
Can anyone explain how to use the PopupExpressions of a PopupDefinition/Popup in relation to the PopupManager?
Let's say I have a simple PopupDefinition defined as below:
   "allowDelete":false,
   "allowEdit":false,
   "allowEditGeometry":false,
   "description":"",
   "expressions":[{
      "name":"expr1".
      "title": "Expression Test",
      "expression": "$feature.NAME",
      "returnType":"string"
   "fields":[{
      "fieldName":"NAME",
      "format":null,
      "isEditable":false,
      "isVisible":true,
      "label":"Name Label",
      "stringFieldOption":"singleLine",
      "tooltip":""
   "media":[],
   "relatedFeaturesDefinition":null,
   "showAttachments":true,
   "showEditSummary":false,
   "title":"{NAME}"
I can set this PopupDefinition to a FeatureLayer, query for Popups and get a result that shows both the Fields and Expressions are available. Passing the Popup to a PopupManager gives me access to the 'DisplayedFields' which I then use to bind to my view. Unfortunately, I don't understand how you access the expressions. I had thought that perhaps they could be referenced as PopupFields by adding additional Field values to the PopupDefinition such as the following:
      "fieldName":"{expr1}",
      "format":null,
      "isEditable":false,
      "isVisible":true,
      "label":"Expression Label",
      "tooltip":""
This however does not appear to work. How does one access PopupExpression results from a PopupManager?
Outcomes
