Widget select (WAB) and geoprocessing service ?
634
09-11-2019 03:56 PM
PierreWeisse1
I am trying to connect a query from a widget (widget-select) under WebApp Builder with a geotraitement service (widget-geoprocessing).
The source web service and the geoprocessing service are from ArcGIS Server.
I have two questions:
1) The widget select documentation has these parameters. (attachment 'ArcGIS documentation'). However, I do not have this possibility. (attachment 'my settings'). I don't have 'Set as Input of Geoprocessing'.
2) What parameters should I indicate in the script to retrieve the query from widget-select?
Thank you for your help
AllenScully
Occasional Contributor III
Hi Pierre -
I have the same issue - I thought my custom GP script was set up and published to allow for the Select Widget results to be used as Geoprocessing Input but I am not seeing that option (in AGOL so I know it's current).
Did you ever figure this out?
One thing I have been able to do is create a layer from the Selection results and use that as input to the Geoprocessing widget, but that's clunky and feels like a work-around
Thanks -
Allen
