I have this interesting problem and hope someone can provide some insight/solution. I have access to full blown ESRI software.
I have property parcels layer with close to 20,000 records. The attributes of this layer contains regular parcel info, plus addresses. There are three separate columns for addressing; Street Number, Street Name, and Full Address.
I want to place a point right at the centre front of each parcel, preferably on the Road line feature that I have. In case where the parcel is on the corner and has access to more than one road, I want to place the point on the road that matches with the address. Finally for each point I need an xy coordinate and an angle for facing the front of the parcel.
I can also do without creating a point. If there is a way to add xy and angle in the parcel feature class for each record, that would work as well.
Any suggestions?
