Pass values from Collector to Survey123
339
09-10-2019 10:22 AM
RonParis
Is it possible to pass values from Collector to Survey123 (built in AppStudio) as per this blog post?
TIA
LanceCole
MVP Regular Contributor
Josh Harris‌,
Yes, Below is HTML that I included on a Collector Pop-up that opens Survey123 generated from AppStudio and passes the asset_id and center values.  You would need to add your Survey123 itemID and use applicable fields in your 123Survey.
<p><a href="arcgis-survey123://?itemID=<place your ID number of survey here>&amp;field:asset_id={ASSETID}&amp;center={Point_Y},{Point_X}">Launch Survey123</a></p>
