I'm having trouble finding where I activate the CAD to Geodatabase tool in Arcmap 10. Where is that tool located in the menu?
Solved! Go to Solution.
Peter,
In the tool box, go to Conversion tools then to "To Geodatabase" to find CAD to Geodatabase.
Here are some instructions on using it:
http://desktop.arcgis.com/en/arcmap/10.3/manage-data/cad/using-the-cad-to-geodatabase-tool.htm
Peter,
One of the easiest ways to search for tools in 10.x is in the menu bar go to Geoprocessing > Search For Tools. In the search text box start type the name or part of the name of the tool you are looking i.e. "CAD" and similar tools will be listed, select the one you re looking to use. Other methods for finding tools can be found in A quick tour of finding tools - ArcGIS Desktop
Peter,
Thanks guys. That worked.
