java.lang.RuntimeException: createContext failed: EGL_SUCCESS
1873
09-10-2019 04:07 AM
VTSVTS
Error occurs when map activity i called.
xml code:
<com.esri.arcgisruntime.mapping.view.MapView
    android:id="@+id/map"
    mapoptions.MapType="Streets"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
    mapoptions.ZoomLevel="16"
    mapoptions.center="19.2190, 72.6701"
    android:layout_centerInParent="true" />
at android.opengl.GLSurfaceView$EglHelper.throwEglException(GLSurfaceView.java:1230)
at android.opengl.GLSurfaceView$EglHelper.throwEglException(GLSurfaceView.java:1221)
at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:1071)
at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1437)
at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1278)
Android Device : OPPO A5s
Model: CPH1909
Android Version: 8.1.0
ColorOS Version: CPH190-9EX_11A_26
by Anonymous User
Not applicable
This question has been asked and answered previously at the following link:
Error createContext failed: EGL_SUCCESS when under Android 4.2.2 application is started
This is a known issue for this release that has not found its way into the release notes yet, we will update the release notes soon.
The issue is that some devices do not correctly report their OpenGL configurations to allow us to create our OpenGL context. We need to be specific in creating the OpenGL context to allow many of our map rendering features to work properly (particularly for things like Vector Tiled Layers). We have implemented a solution which works on most devices, but it will still be problematic on some, especially older devices running older versions of Android.
Please try on another device or the emulator.
by Anonymous User
Not applicable
VTSVTS
Thank you Gary Sheppard‌ for providing the details regard the issue.
It has been observed that few handset of Vivo (Vivo 1902) running Android P (API:28) are also having same problem. Is it possible to do any setting changes in the device and make the application with arcgis android sdk work.
Currently my application is having arcgis android sdk version: 100.6.0
Please advice any possible solution since my application is in production and many of my Vivo and OPPO handset user are facing this problem.
