sdemon -o info -I {users} in ArcGIS 10.6
469
09-09-2019 01:17 PM
JoseSanchez
Occasional Contributor III
Hello everyone,
Environment: SQL Serve rand ArcGIs 10.6.1
When an SDE connection cannot be opened with ArcCatalog. how do you check the  users who are connected,. I am looking for a command similar to the old: sdemon -o info -I {users}
JoshuaBixby
MVP Esteemed Contributor
Well, I would say using ArcPy or any other ArcGIS Desktop tool is out because they would likely use the same underlying code that ArcCatalog uses to connect.
Have you tried:  How To: Obtain a listing of user processes and locks from a geodatabase when there is no ArcSDE serv...
