Question about Scalebar toolkit
690
09-09-2019 07:22 AM
S_MMaruf
Hello guys ,
I want to use scalebar toolkit in  my map application . there is any way to integrate arcgis runtime java scalebar toolkit in project without gradle or maven. in my project i dont use any gradle or maven .. there is other way how to use scalebar feautre in my project?
TylerSchiewe
Yes, you can download the jar from Bintray and add it to your classpath like you are doing with the arcgis-java jar.
Hope this helps,
Tyler
S_MMaruf
This Scalebar's Viewpart is created from logic part but in my project all other map controls eg: zoombutton, pan Moving Button is created using JavaFx Fxml and secneBuilder . can you give me some direction how to develope Viewpart using Fxml or sceneBuilder for ScaleBar toolkit for my map application. it would be great to get some help.
ColinAnderson1
It looks like currently the scalebar doesn't support being used from in FXML. Since the source code for the scalebar is available I think if you modify the scalebar constructor to have a named argument
public Scalebar(@NamedArg("mapView") MapView mapView)
then you should be able to do something like the following in FXML
<MapView fx:id="mMapView" prefHeight="400" prefWidth="400"/>
<Scalebar fx:id="mScalebar" mapView="$mMapView"/>
and it should now hopefully work.
