Arcgis Quick Capture Template in AppStudio
758
09-06-2019 09:25 PM
YuliaMamonova
Occasional Contributor III
Hello Erwin Soekianto,
I am trying to play with quick capture template (not quick report) in app studio 4, and I can't log in with arcgis online credentials when I run it. After I enter credentials, it starts spinning and then just brings me back into choose portal page.
Am I doing something wrong? I properly registered it the same way I did before with other apps.
Thank you,
Yulia
JohnathanHasthorpe
Hi Yulia
The issue was that the license checks are based on the QuickCapture mobile app's client ID. When using your own client ID, the license check was not working. We have made a fix to the template to get around the issue. If you create a new one, you should no longer see this problem.
John
IsmaelChivite
Esri Notable Contributor
Same here.  See video for details. This is a after registering the AppID.
JohnathanHasthorpe
Hi Yulia
John
YuliaMamonova
John,
Thank you!
