Sharing image attachments of the feature classes in ArcGIS Server
1123
08-30-2019 05:34 AM
bext_la
How may l share attach pictures of feature class in Arcgis server. l attach, but in webmap dislpay no image. l don't know why it does not accept. l don't mean publish in portal or Arcgis online.
DerekLaw
Esri Esteemed Contributor
Hi Bakhtiyar,
Please review these help topics:
Hope this helps,
bext_la
Hi Derek
l couldn't find solution to solve problem. Content is mostly about before sharing, but l am looking to share attach image.
DerekLaw
Hi Bakhtiyar,
Based on your original post,
I thought you were asking how to publish a feature class (i.e., share) from ArcGIS Server with attachments - and not use ArcGIS Online or Portal for ArcGIS. Hence why I posted the help links above. If I misunderstood your question - can you please clarify?
Hope this helps,
bext_la
Hi Derek.
Yes. It is right. But your shared post doesn't help solve problem. l think that problems between Sharing and webmap. Why doesn't webmap indicate image in table? Probably in sharing has problem.
