AnsweredAssumed Answered
How to set ClassBreakRenderer on GraphicsOvelay
Question asked by codergrlcom on Aug 25, 2019
Latest reply on Aug 26, 2019 by codergrlcom
I'm trying to create a ClassBreakRenderer and set it on a GraphicsOvelay and cannot get it to work. The renderer works fine on a FeatureLayer, but doesn't work on a GraphicsOverlay that's been created using the same data as the FeatureLayer. I'm not sure what I'm missing here. Is there a sample somewhere that shows how to do this? I pasted the code below, and also attached the repro case, in case someone is up for giving me a hand in getting to the bottom of this. Working with 100.5. Thank you!!!
- Mara
private async void RenderData()
     // Create a new map based on the streets base map.
     Map newMap = new Map(Basemap.CreateStreets());
     // Create an envelope that covers the continental US in the web Mercator spatial reference.
     Envelope continentalUSEnvelope = new Envelope(-14193469.5655232, 2509617.28647268, -7228772.04749191, 6737139.97573925, SpatialReferences.WebMercator);
     // Zoom the map to the extent of the envelope.
     newMap.InitialViewpoint = new Viewpoint(continentalUSEnvelope);
     // Assign the map to the MapView.
     MyMapView.Map = newMap;
     MyMapView.GraphicsOverlays.Add(new GraphicsOverlay());
     // CHANGE THIS FLAG TO SWITCH TEST BETWEEN FEATURE LAYER AND GRAPHICS OVERLAY
     var useFeatureLayer = true;
     if (useFeatureLayer)
          // set feature layer and renderer and add it to the map
          var featureLayer = new FeatureLayer(new Uri("https://services8.arcgis.com/KsXZDThvSinzJ3pq/arcgis/rest/services/test_pipeline/FeatureServer/0"));
          featureLayer.Renderer = CreateClassBreaksRenderer();
          MyMapView.Map.OperationalLayers.Add(featureLayer);
     else
          // set feature table and query it to retrieve all features
          var featTable = new ServiceFeatureTable(new Uri("https://services8.arcgis.com/KsXZDThvSinzJ3pq/arcgis/rest/services/test_pipeline/FeatureServer/0"));
          var queryParams = new QueryParameters { WhereClause = "1=1" };
          var featureResult = await featTable.QueryFeaturesAsync(queryParams, QueryFeatureFields.LoadAll);
          // create graphics from the features and add them to the map in a graphics overlay
          foreach (var result in featureResult)
               var pipeSegment = result.Geometry;
               var graphic = new Graphic(pipeSegment);
               graphic.Attributes.Add("break", result.Attributes["break"]);
               MyMapView.GraphicsOverlays[0].Graphics.Add(new Graphic(pipeSegment));
          // create and set renderer for the graphics overlay
          MyMapView.GraphicsOverlays[0].Renderer = CreateClassBreaksRenderer();
private ClassBreaksRenderer CreateClassBreaksRenderer()
     // Create symbols
     var symbol1 = new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, Color.Red, 7);
     var symbol2 = new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, Color.Yellow, 7);
     var symbol3 = new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, Color.Green, 7);
     // Create class breaks
     List<ClassBreak> listClassBreaks = new List<ClassBreak>
          new ClassBreak("1", "1", 0, 1, symbol1),
          new ClassBreak("2", "2", 1, 2, symbol2),
          new ClassBreak("3", "3", 2, 3, symbol3),
     // Create and return the a class break renderer for use with the "break" field
     return new ClassBreaksRenderer("break", listClassBreaks);
Outcomes
