Is it possible to overwrite elevation layer
307
08-25-2019 03:41 PM
GabrielaOlekszyk
I have elevation layer in portal, that has been published from SDE referencing registered data. I have modified the raster that the layer is using (appended additional area) but I don't see these changes in portal. I thought maybe it is because the extent is now different?
To fix the issue, I then started to look for overwriting option but I can't see it - I only get "share as web layer". Is there any way to overwrite instead?
