Hi folks,
The Utility Network solution pages refer to a specific version of the Utility Network Management extension, e.g.
Electric Utility Network Foundation | ArcGIS Solutions for Electric
Electricity asset package v3.1 --> ArcGIS 2.4 with version 3.0 of the ArcGIS Enterprise Utility Network Management extension
Gas Utility Network Configuration | ArcGIS Solutions for Gas
Gas asset package v2.0.1 --> ArcGIS 2.3 with version 2.0 of the ArcGIS Enterprise Utility Network Management extension
The versioning of UN management extension is not clear ot be. I am correct to think that
version 2 --> Portal, ArcGIS for Server 10.6.x
version 3 --> Portal, ArcGIS for Server 10.7.x. Is this then not supported on 10.6.x?
Other than licencing the UNM on the server, there isn't anything else to install on the server that has a version.
Joep Luijten
utility network extension arcgis utility network Melissa Jarman
The asset packages have versions. I believe the version that this documentation is referring to the Utility Network Release. The version of ArcGIS Pro that is used to create a utility network determines the release for the UN.
Utility network dataset administration—ArcGIS Pro | ArcGIS Desktop
- reference the ArcGIS platform compatibility section
Hope this helps!
I'll confirm with the Solutions team and see if we can clear up the terminology on this topic if so.
