FeatureClass in Pipeline Referencing FeatureDataset created with ArcGIS Pro is read-only from ArcMap
513
08-20-2019 10:51 PM
Cristian_Galindo
Occasional Contributor III
Hello fellows,
I created a Pipeline Referencing Feature dataset, and inside it is created a Point Feature class, I did that using ArcGIS Pro. when I try to access the information from ArcMap, I am able to load the information, its attributes everything, but I am not able to perform edits:
I am using the same credentials to connect to the geodatabase.
According to ArcCatalog, this are the permissions:
What I am missing here?
Thanks.
[EDIT]: this feature dataset was configured with LRS using ArcGIS Pro:
Get started with Pipeline Referencing—ArcGIS Pipeline Referencing for ArcGIS Pro User Help | ArcGIS ...
[UPDATE]: Neither ArcGIS Pro, nor ArcMap has Location Referencing Extension enable.
Asrujit_SenGupta
MVP Regular Contributor
Are you trying to perform the editing in ArcMap using the same user as ArcGIS Pro? Can you connect as DATAOWNER and check.
Cristian_Galindo
I just try, I cannot do any edit
Cristian_Galindo
Yes, I was using the same user. I try unsing the DataOwner user, but the result was the same
