No module named 'arcgis' for import GIS
7136
8
08-20-2019 09:09 AM
MRReddy
 I have ArcGIS API for Python installed and when I use below line, am getting error as
ModuleNotFoundError: No module named arcgis
from arcgis.gis import GIS
c
DanPatterson_Retired
import sys
sys.executable
'C:\\Your_ArcGISPro_install_path\\bin\\Python\\envs\\arcgispro-py3\\pythonw.exe'
# ---- arcgis is installed in
# C:\Your_ArcGISPro_install_path\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis‍‍‍‍‍‍‍‍‍
Do the sys.executable... if it isn't in the same path up and including
Then you are using the wrong python or arcgis was installed incorrectly.
Obviously Your_ArcGISPro_install_path will depend on your setup
JoshuaBixby
MVP Esteemed Contributor
Can you elaborate on how you installed ArcGIS API for Python?
MRReddy
Joshua Bixby‌ Thank you for reply
I didn't install myself, my team member did, he said it comes with pro
and for import arcpy there is no error
JoshuaBixby
ArcGIS Pro ships with 64-bit Python 3.6.8, and your screenshot shows 32-bit Python 3.7.3, so clearly this is not a typical/default installation.
MRReddy
I logged in to My ArcgIS PRo, and in python section, i see version 1.4.1
is that right
JoshuaBixby
Please respond to Dan's question.  As Dan suspects, and I agree with, it seems you are running a different Python distribution than the one bundled with Pro, and the Python distribution you are running doesn't have ArcGIS API for Python installed.
import sys
sys.executable
MRReddy
Dan
My arcgis pro installed path is
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
and i installed pthon 3.7.3 that path is C:\python3.7.3\
my pyscripter python version in pyscripter is
and my python path is to C:\python3.7.3\  Not the Pro installed path
i tried to add path (C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3 ) in pyscripter it gets added and when i ran the script and the settings agian changes to default
can you suggest me
That is a pyscripter problem, it isn't set up properly to use the required python.
