The Product License has not been initialised
5149
08-20-2019 09:04 AM
NadirHussain
Occasional Contributor II
Dear All,
From last two days i am stuck in this error.i have googled it.but could not succeed.i am trying to connect arcsde geodatabase using arcobjects.
license status function return true and when i try to open the workspace factory i face the error "The Product License has not been initialised".please help.
if (LicenseStatus())
Console.WriteLine("Ready with license.");
IPropertySet propertySet = new PropertySetClass();
propertySet.SetProperty("SERVER", "DESKTOP-FQEJI3R");
//propertySet.SetProperty("SERVERINSTANCE", "localhost");
propertySet.SetProperty("SERVERINSTANCE", "sde:sqlserver:DESKTOP-FQEJI3R");
propertySet.SetProperty("DATABASE", "Test"); // Only if it is needed
propertySet.SetProperty("AUTHENTICATION_MODE", "DBMS");
propertySet.SetProperty("USER", "*****");
propertySet.SetProperty("PASSWORD", "*****");
//propertySet.SetProperty("DBCLIENT", "SQLServer");
propertySet.SetProperty("VERSION", "sde.Default");
// Create an SDE workspace factory and open the workspace.
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory");
IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
IWorkspace workspace = workspaceFactory.Open(propertySet, 0); error Line
//CreateMathFunctionRasterDataset();
aoInit.Shutdown();
catch (Exception exc)
aoInitialize.Shutdown();
// If it fails at this point, shutdown the test and ignore any subsequent errors.
Console.WriteLine(exc.Message);
public bool LicenseStatus()
//This sample is designed to perform license initialization on a system
//that may have access to a floating license. An ArcEditor license will be used.
aoInitialize = new AoInitializeClass();
//Check the productCode.
esriLicenseStatus licenseStatus = aoInitialize.IsProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngineGeoDB);
if (licenseStatus == esriLicenseStatus.esriLicenseAvailable)
//Initialize the license.
licenseStatus = aoInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeEngineGeoDB);
//Take a look at the licenseStatus to see if it failed.
if (licenseStatus == esriLicenseStatus.esriLicenseNotLicensed)
//Not licensed.
MessageBox.Show("You are not licensed to run this product");
return false;
else if (licenseStatus == esriLicenseStatus.esriLicenseUnavailable)
//The licenses needed are currently in use.
MessageBox.Show("There are insufficient licenses to run");
return false;
else if (licenseStatus == esriLicenseStatus.esriLicenseFailure)
//The licenses unexpectedly failed.
MessageBox.Show(
"Unexpected license failure please contact your administrator");
return false;
else if (licenseStatus == esriLicenseStatus.esriLicenseAlreadyInitialized)
//Already initialized (initialization can only occur once).
MessageBox.Show(
"Your license has already been initialized; please check your implementation.");
return false;
else if (licenseStatus == esriLicenseStatus.esriLicenseCheckedOut)
//Everything was checked out successfully.
MessageBox.Show("Licenses checked out successfully");
return true;
return false;
aronlangley
I was running my script without signing into arcgis pro/online. the error went away after i signed in.
ShariForbes
New Contributor III
Hello. We have tasks on Task scheduler that run Python 3 scripts. I have scripts that had been running fine for weeks just recently not run at all with this
RuntimeError: The Product License has not been initialized.
I saw your reply, logged into ArcGIS Pro and it is now working. So I guess we have to log in periodically for our scheduled tasks to run? Kind of defeats the purpose of automation.  At least they are running again and I'm glad I saw your reply.
