Survey123 app
1781
13
08-21-2019 11:35 AM
ReneAubut
Hi, the current version in PlayStore will install but wont run on most recent devices. users in the play store report the same bug. It runs well on old devices...
Shwu-jingJeng
Hi Rene,
Could you list the example of new/recent devices which fail to run the field app?
ReneAubut
Am running a Panasonic Toughpad. On the playstore, a user mentioned the same bug with a samsung s3
Shwu-jingJeng
What model of Panasonic Toughpad are you using? Did you receive any message when you try to open the app?
Have you tried 3.6 beta build from our early adopter site to see if newer version works?
ReneAubut
Toughpad FZ-B2. Not sure early adopter would help since i have 30 field techs on the field. They are the ones installing their app. Thanks
Shwu-jingJeng
Hi Rene,
Checking the specs on the website and it listed that Panasonic Toughpad FZ-B2 is running on android 6.0.1. Could you confirm the Android version of the device you are running? And have you updated the latest firmware? Make sure you have enough memory on the device though.
https://pc-dl.panasonic.co.jp/dl/docs/079146?dc%5B%5D=002003&dc%5B%5D=002001&no=1&oc=001037&p1=210&p...
When you said the app won't run, does that mean you clicked the app and nothing happens? Or you encounter error message?
Currently we don't have exact device to run the test in house but if you could narrow down the specs at your side, that would be helpful for us to identify the problem here.
Shwu-jingJeng
Furthermore, there is another issue with 3.5 survey123 app with 32bit/64bit on playstore.
Please this post and try to download from here
 to see if it would work for you.
Survey123 doesn´t run in some devices
ReneAubut
Hi Jeng
just updated my tablet operating system and installed Survey123 v3.6.153. As indicated previously, upon launching, msg appears saying stopped working. Any clue what to do next? Thanks
Shwu-jingJeng
Hi Rene,
Did you download from this link? Survey123 for ArcGIS Resources | Downloads, Training, Videos & Documentation
if so, which one did you download? And what android version did you upgrade to? Are you able to upgrade to android 10?
ReneAubut
To update the operating system on my tablet i simply went to Settings- About - Update. It's still Android 6.0.1 and the core version is 3.14.55.x86_64-ga82ca7e. To update Survey123 i again went to the playstore. If i rather go the the url you mentioned, will i be able to execute the install file once downloaded to the tablet? And which version should i download?
