AnsweredAssumed Answered
Copy Raster Failed ??  Using ArcGIS Pro 2.4.1
Question asked by progis99 on Aug 20, 2019
Latest reply on Aug 20, 2019 by progis99
Has anyone had the same problem as I am ?
Trying to export this to .jp2 and got this problem ??
Parameters
Input Raster C:\home_ARCGISPro\Forest Reserve Maps\Image\NewForestReserveMaps\Test.tif
Output Raster Dataset C:\home_ARCGISPro\Forest Reserve Maps\Image\NewForestReserveMaps\Test5.jp2
Configuration Keyword
Ignore Background Value 0
NoData Value 256
Convert 1 bit data to 8 bit NONE
Colormap to RGB NONE
Pixel Type 8_BIT_UNSIGNED
Scale Pixel Value NONE
RGB To Colormap RGBToColormap
Format JP2
Apply Transformation Transform
Process as Multidimensional CURRENT_SLICE
Build Multidimensional Transpose NO_TRANSPOSE
Messages
Start Time: Tuesday, August 20, 2019 9:23:30 AM
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to copy raster dataset
Failed to execute (CopyRaster).
Failed at Tuesday, August 20, 2019 9:34:57 AM (Elapsed Time: 11 minutes 26 seconds)
I had TIFF succeed but not this one as jp2 format
Reason for this is to compare between TIFF and jp2 and which one is save in memory size...
Can anyone help me out ?
Outcomes
