map grid label rotation
968
08-15-2019 01:40 PM
ChrisBehee1
ArcGIS Pro 2.4.1  have a 45-degree rotation on map layout.  Am trying to get UTM map grid labels to rotate to match the grid lines.  Rotation option in text formatting menu allows selection of 45 degree rotation, but reverts to zero once I apply changes.  Is this a bug?  Is there another way to do this?
CoreGeoscience_Services_Inc_
I'm using ArcGIS Pro 2.7.1 and the same thing happens to me when trying to rotate the grid labels.  Did you manage to figure out a fix or workaround for this?
MariusHelsem
Hi, I am experiencing the same issue in Pro 2.9.2. Did any one of you find a solution?
ZhenyuZeng
Same in the 3.0.2. So long not to repair. Weird.
