AnsweredAssumed Answered
Shift in Georeference Information
Question asked by jaynichol on Aug 9, 2019
Latest reply on Aug 21, 2019 by jaynichol
Recently discovered an issue in exporting .pdf maps and wondered if anyone has seen this before or has a possible solution. Field crew reported a shift between two maps with the same data on them that were produced by myself and a contractor. The relative locations are all the same (maps look identical) but when using avenza the contractors map is approximately 12m off. I tried exporting a pdf using the contractors .mxd and it comes out correct. I believe the contractor is using ArcMap 10.3 and we are using 10.6.1. Could this be an issue? Any thoughts on settings we can check?
Outcomes
