popup location
716
5
08-05-2019 11:13 PM
anjelinaponkerat
Occasional Contributor II
Hi
I,m using search widget in 4.12, when search widget find results and show popup, the popup location is not correct and is far from best location!!! why?
I sent a sample that show this incorrect location:
by Anonymous User
Not applicable
Hi Angelina,
Do you have subsequent code which effect change camera object point location after search widget result return?
RalucaNicola1
Hi Angelina, could you post a code snippet? There's a lot of things that could go wrong, so it's hard to tell what's going on. Another thing to try is if it works in 4.11.
anjelinaponkerat
Hi
It was ok in 4.11, But in version 4.12 this problem appeared. why?
regards
RalucaNicola1
I can't reproduce it (here is my sample where it works: https://codepen.io/ralucanicola/pen/OKZJKe?editors=1000). If it worked on 4.11 it means it might be a bug on our side or an intended change. It would be super helpful if you could post a code snippet of how you are using the search widget so we can reproduce it and get it fixed and provide you a workaround if possible. Does the point layer have any elevation offset?
ChrisShaw
The problem is still present in the example you posted. For example, click on any point, then zoom into the map.
