I get this message when I try to ArcGIS Online. "The underlying connection was closed: An unexpected error occurred on send".
Any ideas on this.
Steve
Solved! Go to Solution.
What product are you using?
Sounds like you need a TLS patch: https://support.esri.com/en/download/7666
Yes It worked for me, i was unable to access ESRI online resources and BASE map
I am experiencing similar error in Arc Gis 10.1
Thanks Kory,
I am using ArcGIS 10.4 I can get online maps with out signing in, but when I sign in I get the message, doesn't make much sense too me.
Thanks Kory,
Downloaded the TLS Patch, everything is a-ok.
Steve
It worked for me as well. I use 10.6 version... Thank you for the solution and please #HashTag #OnlineResourcesNotWorking #ArcGISOnlineNotWorking #UnableToAddBaseMap #BaseMapNotWorking
Was using a 10.5 machine and needed a basemap; encountered the same error message. Running PatchFinder indicated I was definitely missing the TLS patch. Installed it and error went away. 👍
