Service Area Layers Not Rendering Properly in AGOL
604
08-01-2019 08:42 AM
OscarSepulveda_III
I have developed service areas within ArcGIS Pro (v.2.4.0) based upon the following settings:
Network Analyst Settings
with Travel Settings:
  • Restrictions
    • Driving an Emergency Vehicle
  • U-Turns
    • All
  • Advanced
    • Use Hierarchy
    • Simplify Output Geometry
AND I imported a point layer (Fire Station Locations)
I ran the analysis and the outcome rendered properly as shown below.
Correct Service Area Layer Rendering
Then, I published a feature service to AGOL that included all 5 cutoffs.  But, when I viewed the feature layer in AGOL the layers did not render properly.
Incorrect Service Area Layer Rendering
I have tried sorting the table by Cutoff Time back in Pro without success.  Also, moving the layers in the symbology editing field in AGOL without success.  And I can't perform the network analysis in AGOL because I am using the 'Driving an Emergency Vehicle' restriction.
ANY IDEAS????
by Anonymous User
Not applicable
Hey Oscar Sepulveda III‌,
I would recommend creating a Support Case to look at the rendering issue. I haven't seen that specific issue before but Support will be able to take a closer look at the data and workflow.
It is in fact possible to perform network analysis in ArcGIS Online with the Driving an Emergency vehicle restriction. Please see the documentation here about adding restrictions to custom Travel Modes: https://doc.arcgis.com/en/arcgis-online/reference/travel-modes.htm#ESRI_SECTION1_062FBD1B57004A3D85D...
Hope this helps,
Peter
