Survey123 publishing error code: 99 Unable to write
1127
07-31-2019 07:56 PM
JérémiePedoia
New Contributor III
When we try to overwrite our Survey from Survey123 Connect, the error code 99 : Unable to write occurs.
The survey is published with the 3.3.51 Survey123 Connect version.
When we try to publish it from another computer and network, it's works properly.
The publication used to work until we changed the version setting in the published survey to use the newest version.
We went back and selected "use the publised version" because an error ocured during the web form update.
Do you have any clue on this behavior and how to fix it ?
Thank you in advance.
Best regards.
JamesTedrick
Esri Esteemed Contributor
Hi Jérémie,
Apologies for the delay in responding to your post.  It sounds like there is a problem with the copy of the survey on your computer; I would suggest trying to re-download the survey by clicking on the cloud or 'sync' icon to overwrite the old copy and re-publishing. If you continue to see an issue, I would recommend opening a ticket with Support to diagnose what is occurring.
