AnsweredAssumed Answered
Popup and Layerlist
Question asked by yfpower1 on Jul 31, 2019
Latest reply on Aug 2, 2019 by yfpower1
I want to combine the popup function (identify the pixel values or feature attributes for MapService) and layerlist widget, potentially add some other widgets. I follow the example for the ESRI's javascript API description but the widgets seem to be misplaced and the popup does not show in the current location. The content plane has been set to the right and the widgets to the left, but still not working. I would appreciate any inputs regarding this issue.
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>soil map</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/themes/calcite/esri/esri.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.29/dijit/themes/claro/claro.css">
<style>
html, body, .container, #map {
height:100%;
width:100%;
margin:0;
padding:0;
margin:0;
font-family: "Open Sans";
#map {
padding:0;
#layerListPane{
width:25%;
.esriLayer{
background-color: #fff;
.esriLayerList .esriList{
border-top:none;
.esriLayerList .esriTitle {
border-bottom:none;
.esriLayerList .esriList ul{
#search {
display: block;
position: absolute;
z-index: 3;
top: 20px;
left: 75px;
#HomeButton {
position: absolute;
top: 100px;
left: 15px;
z-index: 50;
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://js.arcgis.com/3.29/"></script>
<script>
require([
"esri/dijit/Popup",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/Color",
"dojo/dom-construct",
"esri/map",
"esri/dijit/HomeButton",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/dijit/LayerList",
"esri/dijit/Search",
"esri/dijit/Legend",
"esri/dijit/Scalebar",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"dojo/_base/array",
"esri/InfoTemplate",
"dojo/dom",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function (
Popup, SimpleFillSymbol, SimpleLineSymbol, Color, domConstruct,
Map, HomeButton, ArcGISDynamicMapServiceLayer, LayerList, Search, Legend, Scalebar,
IdentifyTask, IdentifyParameters, arrayUtils, InfoTemplate,
dom
var map, identifyTask, identifyParams;
var popup = new Popup({
fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
}, domConstruct.create("div"));
map = new Map("map", {
basemap: "topo",
center: [-90.125, 40],
zoom: 8,
infoWindow: popup
map.on("load", mapReady);
var rasterURL1 = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
var operationalLayer1 = new ArcGISDynamicMapServiceLayer(rasterURL1, { opacity: .80 });
map.addLayers([operationalLayer1]);
var layerList = new LayerList({
map: map,
layers: [{
layer: operationalLayer1,
showLegend: true,
showSubLayers: false,
showOpacitySlider: true
},"layerList");
layerList.startup();
var rasterURL2 = "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServer";
map.addLayer(new ArcGISDynamicMapServiceLayer(rasterURL2,
{ opacity: .90 }));
var search = new Search({
map: map,
}, dom.byId("search"));
search.startup();
var home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
var scalebar = new Scalebar({
map: map,
scalebarUnit: "dual"
scalebar.startup();
function mapReady () {
map.on("click", executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new IdentifyTask(rasterURL1);
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 1;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0,1];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask (event) {
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask
.execute(identifyParams);
deferred.addCallback(function (response) {
return arrayUtils.map(response, function (result) {
var feature = result.feature;
var layerName = result.layerName;
//alert(result);
feature.attributes.layerName = layerName;
if (layerName === 'Census Block Points') {
var taxParcelTemplate = new InfoTemplate(layerName,
"the oject value is: " + feature.attributes['STATE_FIPS']);
feature.setInfoTemplate(taxParcelTemplate);
else if (layerName === 'KS_FIELD_OUTLINES_SPRING2005_GEONAD27') {
"the oject value is: : " + feature.attributes['FIELD_NAME']);
return feature;
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(event.mapPoint);
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
<div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
<div id="search" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="legendDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="HomeButton" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
</div>
</body>
</html>
Outcomes
